Date/Time: Sun, 19 May 2024 04:37:11 +0000
Program error?
View Count: 626
[2016-08-29 18:37:40] |
User976133 - Posts: 38 |
See attached Chartbook please. 3 charts 1 - 5 min ZB 2 & 3 - 1 min ZB Chart 2 and 3 are identical except the background bar code. 1 says that the 5 min Avg2 > Avg3 (Chart3) the other says Avg2 >= Avg3 (Chart2) The 5 minute chart shows that Avg2 > Avg3 since 8:30 this morning. I would expect the results on chart2 with the code of chart 3 as well. Can you point out what I am missing? |
Chartbook3.cht - Attached On 2016-08-29 18:31:31 UTC - Size: 204.88 KB - 228 views |
[2016-08-29 21:12:17] |
We do not understand this, and this question is not within the scope of our support. If you have a very simple question about an alert formula, you need to clearly express it without the use of a Chartbook. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-29 21:37:02] |
What is the scope of your support? The formula in the alert condition does not work as expected. AND(ID1.SG2>ID1.SG3,CROSSFROMBELOW(ID7.SG1,ID7.SG2)) This formula works AND(ID1.SG2>=ID1.SG3,CROSSFROMBELOW(ID7.SG1,ID7.SG2)) I thought that the inclusion of a picture (via chartbook) would have made it impossible to misunderstand or screw up. I stand corrected. |
[2016-08-29 22:31:43] |
You need to understand it is quite a lot of effort and time for us to understand what it is you are trying to accomplish to begin with and why you are getting the result that you do. Our policy is stated here: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation Based upon the limited understanding we have, this section may be helpful: https://www.sierrachart.com/index.php?page=doc/StudyChartAlertsAndScanning.php#ValueFormat Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-29 22:32:15
[2016-08-30 02:15:49] |
A Chartbook can be helpful to us, but we need this simplified down to a single chart, a single study and a single formula and a simple explanation. Or at least simplified down to the minimum needed to demonstrate what is needed to understand the question. Otherwise, it is getting too complicated. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-30 02:16:21
