Date/Time: Sun, 19 May 2024 07:51:23 +0000
Using the color bar based on alert study
View Count: 651
[2016-08-29 18:00:36] |
User686939 - Posts: 6 |
I created an alert to color bar based on a moving average cross over, which works great but I paints all the bars after the cross How can I make it so that it only colors the exact bar when the cross occurs? thanks |
[2016-08-29 18:37:08] |
Sawtooth - Posts: 4000 |
Use the CROSSOVER function: =CROSSOVER(ID1.SG1,ID2.SG1) |
[2016-08-29 21:39:00] |
Here is the documentation for the CROSSOVER functions: http://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
