Date/Time: Sun, 19 May 2024 05:43:27 +0000
[User Discussion] - Bar Numbering Question
View Count: 840
[2016-08-29 12:08:07] |
infpz - Posts: 826 |
At the end of the day I would like to see how many Renko bars print...but only during the day session from 8:30 to 3:15. I have a chart that is set up for that....but only has the bars for that time frame. I would like see the whole 24 hr session chart but only have the bars numbered from 8:30 to 3:15. I thought maybe I could have two charts...one with 24 hr and one with 8:30 to 3:15. Use the Price/Study Overlay to put the number bars from one chart on the other....but that doesn't work apparently. Any suggestions? |
[2016-08-29 14:29:24] |
This is not supported.
[2016-08-29 15:31:02] |
Sawtooth - Posts: 4000 |
You can do it with the Spreadsheet Study study. -Put this in cell H1: 08:30:00 -Put this in cell H2: 15:15:00 -Put this in cell K3: =IF(OR(A3-INT(A3)>=$H$2,A3-INT(A3)<$H$1),0,IF(AND(A4-INT(A4)<$H$1,A3-INT(A3)>=$H$1),1,K4+1)) -Set the Draw Style of K(SG1) to Value On Low. |
