Date/Time: Mon, 20 May 2024 11:52:01 +0000
Removal of pivot point lines for prior days
View Count: 902
[2016-08-25 16:58:37] |
User171663 - Posts: 5 |
Hi, I wanted to know how to keep only the current days pivot point line and remove the prior days lines. Thanks |
[2016-08-25 17:22:49] |
You need to set the Number of Days to Calculate Input with the study to 1. Refer to: http://www.sierrachart.com/index.php?page=doc/PivotPoints.html#PivotPointsDaily_Inputs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-25 19:50:44] |
[2018-03-04 16:54:19] |
Hi, I am facing the same problem with being able to keep only the current days pivot point lines. Although I am changing the "Number of Days to calculate" input to 1, the prior days pivot point are still showing. |
[2018-03-05 12:30:43] |
User106180 - Posts: 88 |
I have this problem with some studies as well (in particular the Dalily OHLC study), and find that selecting the following removes the previous days lines - Chart > Reload and Recalculate
[2018-03-05 18:47:23] |
Yes you do need to use Chart >> Recalculate when there is a new day.
