Date/Time: Sat, 18 May 2024 06:22:13 +0000
How to recover a corrupted chartbook?
View Count: 8429
[2018-10-31 01:19:46] |
In regards to the abnormal shutdown issue described in the later posts in this thread: I did market reply twice now in the past 10 mins and Sierra closed on me twice now.
We want you to update to version 1833. We did determine there was a problem related to the target triggered move to breakeven functionality that could potentially have led to an exception. Whether this was the cause or not is unknown. There are only a couple of known instances of this particular issue.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-31 16:41:21
[2018-10-31 16:10:02] |
User274676 - Posts: 38 |
Everything is working fine now. I have changed machines. The machine had a faulty hard drive this could be the reason why?
[2018-10-31 16:10:40] |
My data looks fine and my indicators have loaded as expected.
[2018-10-31 16:40:55] |
The machine had a faulty hard drive this could be the reason why? This was probably the reason for the issue in your case.
