Date/Time: Sun, 19 May 2024 10:21:37 +0000
ACSIL - Set to Timespecific bars
View Count: 948
[2016-08-21 16:42:53] |
ejtrader - Posts: 688 |
SC team - I would like to control the Chart time period to "intraday" daily chart (not historical daily chart). I could get this done through sc.SecondsPerBar variable but works only when I start with intraday time based charts(where sc.AreTimeSpecificBars() = true). Is there any function available to set the current chart to Timespecific bars - irrespective of the bar type used(like range/volume etc) to begin with through ACSIL? One second request - Is it possible to make sc.LastTradeType variable available(similar to sc.LastTradePrice & sc.LastSize)? At present pulling this information from T&S structure. However there are occasions when the market is closed etc where T&S size is '0' and this information can't be pulled. Thanks Date Time Of Last Edit: 2016-08-22 05:35:59
[2016-08-22 16:42:02] |
You need to use this variable but it is currently read-only: ACSIL Interface Members - Variables and Arrays: sc.ChartDataType In the next release it will be read/write. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-30 14:19:57] |
SC Team - even with latest version - this issue remains. I am using the following parameters in the code. sc.ChartDataType = INTRADAY_DATA; sc.DaysToLoadInChart = 5; sc.SecondsPerBar = 1440 * 60; // Equivalent of 24 hours - if the chart is started with any timespecific bars - it DOES convert to intraday dailybar with the above parameters. - if the chart started is not a timespecific bar ( like volume/range chart etc ) - it doesn't change to intraday daily bar. Wondering if I am doing something wrong or this way of changing the current chart to intraday daily chart is not supported. thanks Date Time Of Last Edit: 2016-08-30 14:21:39
[2016-08-30 21:56:23] |
We will check on this.
[2016-08-31 10:09:58] |
We added a paragraph to the documentation here about this: ACSIL Interface Members - Variables and Arrays: sc.SecondsPerBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-31 10:10:14
