Date/Time: Sun, 19 May 2024 04:36:46 +0000
On balance volume modified
View Count: 1124
[2016-08-19 20:11:38] |
bercor - Posts: 30 |
I would ask you kindly if there is an indicator similar to ON BALANCE VOLUME, which we know adds the volume bar if the close of the bar is higher than the clode of the previous bar and subtracts it (the volume if the close is more low) that makes this calculation addition or subtraction to the "on-balance volume" according to the market hits the money and a letter. I hope I was clear thanks ps summarizing: a sort of ON BALANCE VOLUME that has as subtraction rule or the sum of the volume according to whether the price has been made wrought hitting the letter (sum) or hitting the money (subtraction) thank you |
[2016-08-20 01:14:24] |
You can modify the On Balance Volume study as you require. Refer to this page: http://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
