Date/Time: Tue, 28 May 2024 04:31:26 +0000
Symbol format question
View Count: 675
[2016-08-19 18:12:55] |
User11942 - Posts: 298 |
Hi SC team, for tradable symbols that are not supported by SC real-time data feed but supported by CQG, which format should I use, F.US.XXXX6 or F.US.XXXX16? I can get data for both but the question is which data are correct. Since recently there is a big difference in data. Thanks. |
[2016-08-19 18:15:27] |
Always use two digit years.
[2016-08-19 18:22:57] |
Even if data with two digit year do not seem correct? Why I can receive data with one digit format then? I'll post screenshots later, busy now.
[2016-08-19 18:33:14] |
Please have a look at screenshots, explanations are there.
Private File Attachment Deleted. Private File |
[2016-08-19 18:37:03] |
One thing we know for sure is if you are using both of these symbols at the same time, that most likely is going to create a data mapping conflict due to the fact that these probably have the same contract identifiers on the CQG side. Use only one of them and reconnect to the data feed after this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-19 18:38:40
[2016-08-19 18:41:25] |
Okay, thanks for the hint. Will try it next week. Unrelated question - any progress on this? This is very useful feature especially for spread traders. Thank you in advance. Forward Curve Date Time Of Last Edit: 2016-08-19 18:58:03
[2016-08-21 11:05:44] |
Nothing further yet with Forward Curves. There are other higher priority tasks we need to finish with first. This is also not so easy to accomplish with the way charts are currently designed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
