Date/Time: Sun, 19 May 2024 11:19:20 +0000
Truncate continuous SCID futures data
View Count: 887
[2016-08-19 17:07:29] |
GrigorHagop - Posts: 18 |
I am using SCID continuous futures data files. In your previous versions the maximum file size could be restricted with the excess dumped into a -1 file. In the current versions this restriction does not exist. Therefore my data files are getting too large. How can these files be restricted either size-wise or oldest date-wise? The preferred method would be a method of truncating off data older than a specified date or back a specified number of days from current date. Thank you in advance for your assistance.
Date Time Of Last Edit: 2016-08-19 17:14:59
[2016-08-19 17:18:26] |
We definitely do not recommend this outdated method for continuous futures contract charts. Follow the method documented here: http://www.sierrachart.com/index.php?page=doc/ContinuousFuturesContractCharts.html Also there is this feature to reduce the size of files: http://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#DataFileManagement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
