Date/Time: Thu, 16 May 2024 20:14:39 +0000
flex renko high/low values
View Count: 770
[2016-08-18 22:47:29] |
onnb - Posts: 661 |
I have a chart with Flex Renko I am using the cross hair to look at high/low prices. What I see in the tools value window does not match what I see visually. In more details On an up bar, where there is a wick on the low, the low of the bar matches - both visually and in the tools value window On an up bar, where there is no wick on the low, the low values do not match. I am seeing that in the tools value window, the low is higher than what I see visually. Not sure why that is. |
[2016-08-19 03:21:12] |
This is all documented in detail here: http://www.sierrachart.com/index.php?page=doc/RenkoCharts.html#RenkoOHLCValues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
