Date/Time: Thu, 16 May 2024 05:34:03 +0000
Update intraday charts
View Count: 609
[2016-08-18 16:31:33] |
User26753 - Posts: 43 |
I have a chartbook with various stocks in charts of 60 minutes. Every day each one of these charts updates every tick, but there are two -AAPL and FB- which donĀ“t update. I only can see the yesterday chart but not the today chart. The strange thing is that this only happens in these two charts. I attached the screen captures of the configuration of these charts. Thank you in advance |
AAPL 1.PNG / V - Attached On 2016-08-18 16:30:48 UTC - Size: 48.93 KB - 180 views AAPL 2.PNG / V - Attached On 2016-08-18 16:30:55 UTC - Size: 39.63 KB - 191 views AAPL 3.PNG / V - Attached On 2016-08-18 16:31:02 UTC - Size: 38.69 KB - 201 views |
[2016-08-18 17:29:19] |
For those particular symbols you will need to use the stock symbol format which specifies the Primary Exchange: http://www.sierrachart.com/index.php?page=doc/IBSymbols.html#Stock Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
