Date/Time: Thu, 16 May 2024 10:37:37 +0000
Every Tick on Right Side of Grid
View Count: 647
[2016-08-18 16:07:18] |
dBassFour - Posts: 16 |
Hello, In order to see every tick 2100.25, 2100.50, 2100.75 on the ES, I have to zoom out so far that I miss price action as seen in this image. There is clearly room to include additional ticks- do you recommend any way to make this chart a bit easier to read per tick? I have to guess what a price level is. -Dion |
2016-08-18_1203.png / V - Attached On 2016-08-18 16:06:55 UTC - Size: 67.19 KB - 200 views Attachment Deleted. |
[2016-08-18 16:16:53] |
* Also, can I highlight Whole numbers so its easier to see 4 Ticks? Thanks! |
[2016-08-18 17:33:06] |
You need to set the Scale Increment as is documented here: http://www.sierrachart.com/index.php?page=doc/Scaling.html#ScaleWindow Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
