Date/Time: Thu, 16 May 2024 19:38:41 +0000
VWAP not drawing on chart
View Count: 791
[2016-08-18 12:33:59] |
wirrell - Posts: 1 |
Hi, I'm trying to add VWAP as a study to a chart. Although the study seems to be added and the VWAP is displayed as a number at the top of the chart, the VWAP lines are not drawn on the chart. I have tried moving the study to other regions but it does not draw on these regions either. Screenshot attached, seen VWAP number posted at the top but no line drawn. Any help would be greatly appreciated. Many thanks, George |
Capture1.PNG / V - Attached On 2016-08-18 12:32:36 UTC - Size: 68.95 KB - 216 views |
[2016-08-18 17:59:24] |
Follow through the instructions here to reset the Volume Weighted Average Price study to default: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#CustomDefaultStudySettings After that is done remove it from the chart and Add it again. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
