Date/Time: Thu, 16 May 2024 11:21:51 +0000
Simple Range Function
View Count: 671
[2016-08-18 04:19:08] |
User147461 - Posts: 33 |
In addition to the TrueRange function would you please consider adding a Range function as well to the scstudyfunctions.cpp file? float Range(SCBaseDataRef BaseDataIn, int Index) { return BaseDataIn[SC_HIGH][Index] - BaseDataIn[SC_LOW][Index]; } Thank you! |
[2016-08-18 04:32:00] |
This function will be in the next release: float GetRange(SCBaseDataRef BaseDataIn, int Index); Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-18 04:44:32] |
Maybe also add the single step function as well: SCFloatArrayRef Range_S(SCBaseDataRef BaseDataIn, SCFloatArrayRef Out, int Index) Thank you! |
