Date/Time: Wed, 21 Oct 2026 15:14:45 +0000
I can´t login into Sierra Chart
View Count: 1034
[2016-08-17 16:02:01]
User905901 - Posts: 18
I can´t login into Sierra Chart (sw for trading and analysis, not my account). I downloaded Prerelease version (Help>>Download Prerelease) and I can´t login into Sierra Chart now. I tried to restart my PC for two times.
How can I solve it?
Thanks.
Regards
[2016-08-17 16:11:26]
Sierra Chart - Max - Posts: 5982
At the present time newer versions of Sierra Chart do not support Windows XP because we are using a newer Microsoft compiler.
We are still seeing if we can support Windows XP.
For now follow through the instructions here:
http://www.sierrachart.com/index.php?page=doc/download.php#Rollback
Install version 1448. Let us know if you have any further problem.
Sierra Chart Support
[2016-08-17 16:33:59]
The problem was solved. Thanks.
