Date/Time: Sun, 19 May 2024 10:21:22 +0000
[User Discussion] - MARKER_TRIANGLEUP, MARKER_TRIANGLEDOWN - Member
View Count: 601
[2016-08-16 19:37:47] |
sampater - Posts: 243 |
How can i control a member Draw Outline Only (Hollow) by sc.UseTool()?
[2016-08-30 21:35:52] |
SC Engineering, Can you add the possibility to control this member by sc.UseTool(), please? Thank you |
[2016-08-31 03:36:17] |
There is not supported for a hollow triangle as a drawing tool.
