Date/Time: Thu, 16 May 2024 16:16:54 +0000
How to show point and figure chart?
View Count: 2040
[2016-08-16 13:50:30] |
User349605 - Posts: 11 |
Sorry bro, Even I read ref. page: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s140, I still can't add it into my chart. Can anyone show me the direct path to add? I try following two way, but none is my need. 1. Chart → Chart Settings → Graph Draw Type, choose "Point and Figure XO" 2. Analysis → Studies → add "Point & Figure Chart" into Studies to Graph: What I want is like your example as attached. Thanks, Fanhow |
[2016-08-16 17:42:12] |
You need to add the Point and Figure Chart study to the chart following these instructions: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#AddingModifyingStudies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-17 01:31:04] |
I do add the Point and Figure Chart study to the chart, as attached "2.jpg". However, my chart is changing to "3.jpg", not like your sample showing as O/X (1.jpg). How come? |
[2016-08-17 20:29:47] |
Refer to the instructions here to change the Graph Draw Type for the study: http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#ScalingPointAndFigureChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-17 20:30:57
[2016-08-18 01:23:45] |
Can you just tell me step by step to set up this function? That will be direct and better help. I follow your link and set, but my chart is as attached, not consisted by OOXX... |
[2016-08-18 04:23:02] |
It appears that you have the Graph Draw Type set correctly. You need to go into the Study Settings window for that Point and Figure chart study following these instructions: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#AddingModifyingStudies Change the Box Size input to 100. If that is not enough, then make it 200 and keep increasing it as necessary. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
