Date/Time: Wed, 15 May 2024 17:22:28 +0000
Approach to adjust attached orders of either side of an OCO order
View Count: 693
[2016-08-13 17:47:11] |
@sstfrederik - Posts: 403 |
Hi, I am looking to an approach to change have different attached orders to an OCO order. I am working with SCT_ORDERTYPE_OCO_BUY_STOP_LIMIT_SELL_STOP_LIMIT. The goals is to have one set of Targets and stops as attached orders for the BUY_STOP_LIMIT and a different set for the SELL_STOP_LIMIT. I guess right now the only approach would be to modify each individual order after the OCOorder has already been submitted. Would it be possible to add a different way of dealing with OCO orders in Acsil? For instance define each side of the OCO order separately as a different order and than combine the two orders to be used as an OCO pair? This would make this far easier to implement. Any other approaches are appreciated. Thanks. Frederik |
[2016-08-13 23:28:52] |
Refer to the documentation before posting these questions here. This is supported. Refer to: http://www.sierrachart.com/index.php?page=doc/ACSILTrading.html#TargetOffset Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-14 03:17:25] |
I see, thanks for the support. i misread the documentation. I guess that why there is a support board.
