Date/Time: Tue, 14 May 2024 14:58:04 +0000
HD Request # 7 | Error downloading historical Daily data for ESU16-$INX...
View Count: 1524
[2016-08-13 01:56:48] |
User884038 - Posts: 4 |
I have the Sierra Chart #5 service and CQG via AMP. I setup CQG according to your site, including Connect to Market Data Service = False. When connecting it seems successful but when opening a symbol I get the message above in the log. I also briefly see Download Failed in the chart window when opening the symbol
[2016-08-13 02:30:08] |
The symbol ESU16-$INX is not supported unless you use the Sierra Chart Exchange Data Feed: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#StockIndexPremiums Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-13 02:30:48
[2016-08-13 03:23:40] |
Ok, maybe I misread something - I'm just trying to get live and historical data for the ES...is that not the right symbol for your system?
[2016-08-13 11:02:22] |
That is a Stock index premium symbol. In Global Settings >> Data/Trade Service Settings, you need to set Connect to Market Data Server = True. Here are the CQG setup instructions: CQG Trading Platform Service: Setup Instructions The symbol you need to use is in File >> Find Symbol >> Futures. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-13 11:03:05
[2016-08-13 13:41:41] |
Now I get the following errors when trying Historical and Intraday: HD Request # 5 | Error downloading historical Daily data for ESU16-$INX. The symbol or data type is not supported with your account type. | 2016-08-13 09:38:26 HD Request # 6 | Error downloading historical Intraday data for ESU16-$INX. The symbol is unknown to the server. | 2016-08-13 09:39:17 AMP provided me with: (08:37:52 PM) AMP | Miro: CQG + Sierra setup (08:38:08 PM) AMP | Miro: http://www.sierrachart.com/index.php?page=doc/CQGTrading.php (08:38:37 PM) AMP | Miro: Package 5 |
[2016-08-13 13:54:48] |
Why are you using that symbol? No need to answer that question. We have made it clear that you do not have access to that symbol and we told you where to find the futures symbols. This is in File >> Find Symbol >> Futures. Follow our instructions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-13 14:25:49] |
Sorry must have missed that part - thanks for kindly pointing me the right way 20 years of making small software companies into big ones and the setup wasn't as obvious/easy as I hoped |
