Date/Time: Wed, 15 May 2024 06:55:23 +0000
Overlay Countdown Timer on Different Chart with Different Timeframe
View Count: 712
[2016-08-12 18:47:10] |
absorrel4 - Posts: 92 |
I have two charts running side by side...one is 5 min chart and the other is a 10 second chart of the same instrument. Is there a way that I can put the countdown timer for the 5 minute chart on the 10 second chart?
[2016-08-12 19:14:12] |
No, this is not supported.
