Date/Time: Tue, 14 May 2024 23:43:17 +0000
Trade Activity Log - Fractional Price Format, and Highest/Lowest Prices Traded
View Count: 949
[2016-08-10 00:20:26] |
User948528 - Posts: 108 |
1. Can you allow TAL to show prices in decimal display format for instruments like ZB 30 year Treasury Bond Futures, where the chart is set to show 0.00001 price format instead of fractions? 2. Can you add option to allow Runup/Drawdown to be displayed as Highest Price and Lowest Price traded during position instead? Date Time Of Last Edit: 2016-08-10 00:20:50
[2016-08-10 06:21:20] |
1. You need to change the Price Display Format through Global Symbol Settings for this symbol: Global Symbol Settings This is the only way. 2. We will add these additional fields. Are you referring to the Trades tab of the Trade Activity Log. Please confirm. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-10 12:46:50] |
1. Perfect. 2. Yes, on the Trades tab of the Trade Activity Log. Thank you for the great quick support, and fast changes. Reminds me of the old days where requests would get implemented immediately. Thumbs up! |
[2016-08-10 23:40:13] |
This is now done and will be out in the next release. This was able to be done quickly because it is not much work to implement and we see the value of it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-06 14:30:08] |
Highest and lowest price while open are in the TAL now, but don't seem to be working correctly for me, v1459.
2016-09-06_10h27_08.png / V - Attached On 2016-09-06 14:29:23 UTC - Size: 43.09 KB - 245 views |
[2016-09-06 21:01:24] |
We need to see how we can duplicate this problem. So we need some time to look into this. Make sure you are not using the Order Fill Calculated Trade Positions: http://www.sierrachart.com/index.php?page=doc/TradeStatusWindows.html#UsingOrderFillCalculatedPosition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-06 21:03:47
[2016-09-07 15:48:25] |
Not using Order Fill Calculated Trade Positions.
