Date/Time: Sat, 18 May 2024 04:05:04 +0000
Numbers Bar Calculated Values - Average Volume per Trade
View Count: 1279
[2016-08-08 07:37:35] |
User787778 - Posts: 139 |
When using a Color Background Based on Alert Condition, with the alert condition set to "id1.sg15>2.8", the study highlights bars where the value of the calculation is 2.4 - 2.7. If I change the study setting to Volume per Second(id1.sg36), the correct bars are highlighted. Thanks inadvance |
[2016-08-08 15:34:00] |
You will need to adjust the Value Format of the Numbers Bars Calculated Values study: https://www.sierrachart.com/index.php?page=doc/StudyChartAlertsAndScanning.php#ValueFormat Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-08 17:54:52] |
Am I correct in saying that the user has no control over the Value Format held by the system, when trading ZB @ 1/32? What value format does the system hold for ZB when 1/32 is selected? Would this impact the error that I get on the Average Volume per Trade? |
[2016-08-08 18:29:33] |
You can control the Value Format. You just have to set it for the study itself. You can use whatever you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
