Date/Time: Sat, 18 May 2024 04:55:06 +0000
Alert Sound Number Placeholders only go to 150
View Count: 657
[2016-08-06 19:42:44] |
User75277 - Posts: 33 |
Howdy, I really need to have more numbers so I can assign more sounds without destroying the sounds that I have. My group trades multiple markets and we all want to have the same setups so out charts, etc are compatible. I'd like more but you could at least go up to 256. No? |
[2016-08-06 21:45:38] |
There are no plans to add more but you can play your own sound files using ACSIL: sc.PlaySound() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-07 12:12:59] |
Howdy, Can you provide a link to an example of how to do these additional sounds with ACSIL? It seems overly complicated just to give a user the options to use a wide range of sounds for the very wide and very flexible chart possibilities for sound alarms.
[2016-08-07 18:50:48] |
The documentation already makes reference to example code for that function. The first step is to understand the Advanced Custom Study Interface and Language: Advanced Custom Study Interface and Language (ACSIL) This is not going to be easy. So it may be best just to disregard all of this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-07 18:51:10
