Date/Time: Sun, 19 May 2024 12:36:24 +0000
Vertical Line Tool - Issue
View Count: 659
[2016-08-06 13:28:38] |
sampater - Posts: 243 |
Steps to the issue: 1) In the Vertical Line Tool there is checked an option Copy Config Name To Text and a field Config Name has a text. 2) Add a vertical line by this tool. 3) Change a color of this vertical line. 4) A color of the Text of this line do not change. |
[2016-08-06 13:46:48] |
This will be solved in the next release.
