Date/Time: Sun, 19 May 2024 12:15:31 +0000
Download Failed
View Count: 666
[2016-08-06 01:22:53] |
User502237 - Posts: 6 |
I'm suddenly getting the message Download Failed in a red box when I load a chart and it updates. I was fooling around with the data services settings earlier trying to fix incorrect Value Area Levels, but got nowhere with it and now I'm getting this message... The only thing I did was switch over to the Sierra Chart Data feed to see if I'd still have the same problem with value area levels... then switched back to Rithmic... and now I'm getting this download failed message. Thanks.
[2016-08-06 09:14:05] |
That might not be unusual over the weekend with Rithmic. Wait until Sunday evening and let us know if you still have a problem. Also, log into this Support Board with your current Sierra Chart account with Help >> Support Board. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
