Date/Time: Wed, 21 Oct 2026 14:36:20 +0000
desk top icon
View Count: 1941
[2016-08-03 15:15:54]
User754167 - Posts: 2
the only way i can open my charts is by redownloading it each time...i never got an icon to use..how do i get one?
[2016-08-03 17:02:17]
We are solving this now. Just give us about 10 more minutes.
[2016-08-03 17:19:47]
Install Sierra Chart again from this page:
https://www.sierrachart.com/index.php?page=doc/download.php#download
When the installation is complete you should now have the shortcuts on the Desktop and Start Menu.
There are options to install shortcuts on the Installer window interface. You needed to manually enable those, but now they are enabled by default.
Let us know if the shortcuts have still not been created.
Date Time Of Last Edit: 2016-08-03 17:20:24
[2016-08-17 15:28:37]
ty that worked...NOW...my question is...i have one day left on my free trial..but i have a TD ameritrade account..don't i get the charts for free using them ? and if so...how can i make the charts be LIVE not SIM?
thx
[2016-08-17 16:15:25]
Sierra Chart - Max - Posts: 5982
1. Your account has been activated and/or reset.
If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu.
After your Sierra Chart usage time ends, you need to pay for additional usage time through "Help >> Add Usage Credit".
2. What is meant by "how can i make the charts be LIVE not SIM?"
Sierra Chart Support
[2016-08-17 18:17:58]
2. Refer to:
http://www.sierrachart.com/index.php?page=doc/Trading.html#DifferenceBetweenSimAndNonSim
