Date/Time: Fri, 03 May 2024 10:01:09 +0000
Trying to change bottom numbers
View Count: 2735
[2013-03-30 08:32:08] |
emjay2d - Posts: 5 |
The bottom numbers on the screen shown in attachment are the numbers im trying to change. I just want to see numericls in increments of 30. I searched and tried my best for a very long time... These are the numbers im referring 2! http://oi46.tinypic.com/ixdoaa.jpg Date Time Of Last Edit: 2013-03-30 08:32:37
[2013-03-30 08:51:39] |
So you want the timescale to be every 30 minutes?
[2013-03-30 10:16:58] |
Sigh i cant explain it. I want it not to display silly numbers like this "3:33,3:38,3:43:3:50" and display numbers like this "3:30,3:40,3:50,3:60" etc.. again im a failure at explaining. |
[2013-03-30 20:29:46] |
Right, this is not supported unless you were to set the time frame of the bars to 10 minutes.
[2013-03-31 02:38:53] |
TechTrader - Posts: 116 |
An option to replace the time scale values with time values associated with Chart> Chart Settings> Advanced Settings 2 >Vertical Grid Lines would achieve a neat solution. I'm not a programmer so I have no idea of what would be involved to achieve this. |
