Date/Time: Sat, 18 May 2024 07:14:26 +0000
Chart Trading Order Line
View Count: 1744
[2016-07-29 18:14:46] |
Integral Trader - Posts: 33 |
Hello, Is there a way to reduce the length of the Chart Trading Lines? You can see from the attached image, the order entry line extends all the way across the chart. I'm looking to reduce the length of the order fill line as well as profit target and stop order lines. Thanks, Kris |
[2016-07-29 19:29:33] |
Yes. This is documented here: Chart Trading and the Chart DOM: Size and Positioning of Working Orders Lines, Position Line, and Order Fills Displayed On Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
