Date/Time: Tue, 10 Feb 2026 01:50:48 +0000
Opening a Sub-Instance at Startup
View Count: 1592
| [2016-07-27 06:47:39] |
| CarlRostron - Posts: 80 |
I have created a new 'Instance' but I want this to open when I open my main Sierra Charts application. I noticed there was a box in the Global Settings --> General Settings --> General 1 tab named 'Instances To Run on Startup:" but I am unsure as to what to type in this box. Please can you advise? Thank you |
| [2016-07-27 06:49:16] |
Enter 2 If you also look at the documentation for the General Settings window you will find documentation for that setting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-27 06:50:22
