Date/Time: Sun, 05 May 2024 15:16:16 +0000
Support/Resistance lines for True Strength Index
View Count: 1529
[2013-07-18 12:02:13] |
Ronin - Posts: 35 |
Is it possible to create the 2 lines that exist on RSI for TSI? (see attached) I want to use it for support/resistance the same way I use it on RSI Thanks in advance Date Time Of Last Edit: 2013-07-18 12:02:28
[2013-07-18 12:04:56] |
Yes. Please refer to the documentation here for this: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#AddingHorizontalLine Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
