Date/Time: Sat, 18 May 2024 12:27:32 +0000
Point & Figure Chart
View Count: 1853
[2016-07-26 17:57:58] |
User657627 - Posts: 3 |
Hi, I use a 4 Point & Figure chart in the ES and have noticed at times new bars are created with 3 price levels ticked instead of 4. See the attached image from this morning. I see other charts, like Market Delta, where the Point & Figure turn is at 4 ticks, as I would expect. This sometimes creates a few extra bars that are not needed. Chart settings are 1-4 for Point & Figure, with tick size 0.2500000. What can be done about this? Thanks |
ES 4 P&F.PNG / V - Attached On 2016-07-26 17:57:45 UTC - Size: 43.73 KB - 344 views |
[2016-07-27 10:38:50] |
When providing an image of the chart use this method only: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Repost the image of the chart. Your chart image is not acceptable as it is because we cannot see the timescale. We also need to know the Chart >> Chart Settings >>Session Times you are using in the chart. And we need to know the Time Zone Setting you have set Sierra Chart to: Time Zone Setting Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-27 12:56:19] |
Here is the chart image: http://www.sierrachart.com/image.php?Image=1469623755884.png Session Times: Start Time 13:30:00 End Time 13:15:00 Evening Session = NO New Bar At Session Start = YES Load All Weekend Data Time Zone Setting = Phoenix (-7 MST) Thanks |
[2016-07-29 10:55:39] |
Disregard the prior response which has been hidden. We thought there was no problem, but we realize there is. This is a relatively new setting which has replaced the Point and Figure Chart study and we need to do some more work on it. You can also use Reversal bars which are very similar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
