Date/Time: Sun, 12 May 2024 10:45:52 +0000
Keep getting this error
View Count: 855
[2016-07-26 14:40:31] |
User360283 - Posts: 440 |
Error setting the system Date-time. Windows error code 1314: A required privilege is not held by the client. | 2016-07-26 09:17:35 * HTTP connection to www.sierrachart.com:80 (46) | Closed. No error. | 2016-07-26 09:17:40 HTTP connection to www.sierrachart.com:80 (46) | Shutdown and closed. | 2016-07-26 09:17:40 The error does not occur if I UNCheck General Settings Periodically Set System Date Time from Server. But when I do this, in a while I get an error message from Sierra that time is not synchronized. How to fix? |
[2016-07-26 18:50:59] |
Therefore, you cannot use the feature to set your system date-time from the server. More information about this is here: Global Settings Menu: Set System Date-Time from Server (Global Settings menu) But when I do this, in a while I get an error message from Sierra that time is not synchronized. This means your computer's time is not being maintained accurately. This is unusual. You would really need to contact your computer hardware provider about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-26 18:51:14
