Date/Time: Thu, 09 May 2024 22:11:26 +0000
Free trial no data
View Count: 706
[2016-07-25 15:53:32] |
User345888 - Posts: 1 |
On Startup I get the message 'Your computer clock is off by 80.799999713898 seconds. Check it and refer to help topic 38 for further information.' I tried the Data Settings> Time Zone (Los Angeles), Global Settings > Set System Time From Server, General Settings > periodically Set System Time from Server ... not seeing data except only EURUSD.dly under File> New/ Open historical, also many menu items are grayed out. Thanks.
[2016-07-25 16:11:53] |
Tell us the symbol of the chart that you do not see data for. And post a copy of the Message Log by following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
