Date/Time: Fri, 10 May 2024 04:43:36 +0000
Data access
View Count: 711
[2016-07-24 13:43:45] |
User847023 - Posts: 4 |
How can i access the exact values of an oscillators at previous index, for example : cci, rsi, to create a buy or sell signals with my acsil study. Thank you for your help
[2016-07-25 04:22:07] |
Refer to the documentation here about array indexing in ACSIL: http://www.sierrachart.com/index.php?page=doc/ACS_ArraysAndLooping.html Basically you would use sc.Index - 1, assuming the study uses automatic looping. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-25 04:22:15
