Date/Time: Fri, 10 May 2024 04:57:25 +0000
Name of horizontal line
View Count: 740
[2016-07-24 05:59:59] |
TradingMarketProfile - Posts: 120 |
Hello, As you can see on the chart, i can not give a name in horizontal line config, just the name of the config on TC8 (for exemle) but not on the chart like before is it me or it is because of the new version ? Thanks |
horizontal line.PNG / V - Attached On 2016-07-24 05:59:49 UTC - Size: 59.79 KB - 218 views |
[2016-07-24 07:18:03] |
Refer to Labels >> Copy Config Name To Text here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#CommonToolConfigSettings This has been tested and works properly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-25 05:14:50] |
yes working i forgot this option, my mistake Thanks |
