Date/Time: Sat, 05 Jul 2025 18:31:10 +0000
Read Data folder path function
View Count: 1054
[2016-07-23 21:32:39] |
enemyspy - Posts: 306 |
Thank you.
Date Time Of Last Edit: 2016-07-23 21:34:03
[2016-07-23 21:33:14] |
This will be added to the next release: SC.DataFilesFolder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-27 20:47:20] |
Ok so Now using this in the prerelease. Thank you for adding this However when doing the following. SCString DataFolder;
DataFolder = sc.DataFilesFolder; //or DataFolder = sc.DataFilesFolder.GetChars(); The string value is: + DataFolder {m_String=0x012183d8 "ÌÌÌÌÌÌÌ$\x3p\x6ÌÌÌÌÌÌÌÌd\x2p\x6ÌÌÌÌÌÌÌ̤\x1p\x6ÌÌÌÌÌÌÌÌä" m_OwnString=1 m_IsModified=...} SCString. Is that how it it is intended to read? I was able to accomplish what I need to do by parsing the substring of the Folder part from: sc.DataFile |
[2016-07-27 21:19:57] |
No, that is not correct but this could happen if you changed the Data Files Folder after the study using it has been added to the chart.
