Date/Time: Sat, 11 May 2024 10:14:21 +0000
TPO count
View Count: 1723
[2016-07-23 06:12:15] |
TradingMarketProfile - Posts: 120 |
Hello, Is it possible for you to add the TPO count on top or bottom of the profile? above / below POC without tails in reel time Thanks exemple on the chart |
tpo count.PNG / V - Attached On 2016-07-23 06:11:32 UTC - Size: 21.17 KB - 672 views |
[2016-07-23 21:35:08] |
As a general rule that was decided years ago, this type of information will not be displayed on the chart itself. It is only available as documented here: https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#TextInformation Not sure what you mean by "without tails". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-23 21:35:46
[2016-07-24 05:56:08] |
Ok i understand your way but the numbers of TPO are on chart (on the left of the profile) anyway, so i can't see the difference if we can get this option because we can do it with paper it's just easier and no loosing time. Tails are the top and bottom single print on the profile (see attachment) and tails don't have to be counted on the TPO count even in reel time during the day Thanks Sorry for my english :) |
[2016-07-24 10:11:41] |
Why would you do the calculation on paper? For what purpose? What you are looking for is already calculated and available here: https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#TextInformation We will include a new input in the TPO Profile Chart study named Ignore Singles in TPOs Above/Below POC. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-25 05:22:50] |
i'm using tool window to see what i need but it takes time to do it when you have detached window i ha ve to clic on the main window, on the chart value tool and back to my chart and clic again on the chart to see the tool window so i'm loosing time but no worry i will do it again lol Thanks anyway :) |
[2016-07-25 05:56:53] |
You just need to go to Window >> Chart Values Window on the detached chart. You can size and position it as required. Here is an example: http://www.sierrachart.com/image.php?Image=1469426166254.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
