Date/Time: Tue, 28 May 2024 17:13:19 +0000
Change Order QTY Interval
View Count: 897
[2016-07-22 15:24:48] |
dBassFour - Posts: 16 |
Hello, Is there a way to modify the Interval of a STOP order? As seen in this image? I can't find the setting anywhere. Thank you, |
[2016-07-22 17:07:51] |
You need to change the Default Order Quantity setting for the symbol ??? in the Global Symbol Settings. Instructions are on this page: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
