Date/Time: Sun, 19 May 2024 14:30:31 +0000
Volume at Price Chart Load issue
View Count: 728
[2016-07-21 16:52:18] |
Integral Trader - Posts: 33 |
When trying to load Volume at Price on my chart and moving the profile to "Right" alignment it crashes Sierra with an error message saying the program needs to close. Then closes when I press OK. Tried multiple times on different charts and consistently gives me this error. Any ideas, I'm running version 1446. Thanks |
[2016-07-21 16:59:32] |
We tested this and could not duplicate the issue. Could you provide us the Chartbook you are doing this with so we can test using that Chartbook. Here are instructions to attach it: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile It can be privately attached. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-21 18:34:36] |
Attached is the ChartBook Thanks |
[2016-07-22 01:41:17] |
We see there are custom studies you are using. Most likely this is caused by one of those studies. Follow the instructions here to use Safe Mode: https://www.sierrachart.com/index.php?page=doc/helpdetails17.html#h17.1 We still cannot duplicate the problem with your Chartbook. So this is further indication the issue is with the custom studies. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-22 11:33:36] |
OK, Thank you for checking this for us. Best, Kim |
[2016-07-22 11:57:33] |
Does using Safe Mode resolve the problem?
[2016-07-22 12:25:37] |
I just successfully loaded the Volume at Price Study in this chartbook in safe mode. Then relaunched Sierra out of safe mode and all loaded successfully. Thank you :). |
[2016-07-22 16:38:27] |
It sounds like you are still going to have a problem at some point again and that the problem may be with the custom studies.
