Date/Time: Mon, 29 Apr 2024 06:21:59 +0000
References to Other Spreadsheets Windows
View Count: 1350
[2013-07-17 17:00:19] |
robwa - Posts: 5 |
"Working With Spreadsheets" states that your new "high performance spreadsheet" (expected soon) will not support references between different Spreadsheet windows. My chartbook contains a spreadsheet for Autotrading. Trades are initiated thru the trade entry cells (K3 and M3), which reference formulas from another spreadsheet in the chartbook, where the trade logic is contained. Will my trades not be recognized by the new spreadsheet? If this is the case, it appears that I must continue to use my existing Sierra Chart version. Is there a workaround? |
[2013-07-17 18:32:19] |
There is a solution to this and you just need to make sure that all of the data is outputted to the same Spreadsheet. We discuss this more here: References Between Spreadsheets Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
