Date/Time: Sun, 19 May 2024 06:11:55 +0000
LMAX DTC - Modify position request failed
View Count: 576
[2016-07-14 17:34:32] |
User825874 - Posts: 1 |
I had an open position, trading on chart with a Stop and Limit Order set. I could not adjust/Modify with the following error:- Order modification failed | LMAX Live Trading - DTC order update (Order cancel/replace reject). Exchange ID: AAGG+QAAAAL1YiBw. Info: Order modification failed | Order modification reject. Text: PRICE_NOT_VALID. Internal Order ID: 19711. Service Order ID: 10706. Symbol: UK100 | 2016-07-14 16:49:28 * All looked fine and i was within paramaters and was actually moving stops out.. The Open Orders were also not visibke on the LMAX Web interface? Any Ideas here? Thanks David |
[2016-07-14 18:02:35] |
This is a rejection from the LMAX server. Ask LMAX about this. Tell them what price you were modifying the order to and what the price of the symbol was at the time. The Open Orders were also not visibke on the LMAX Web interface?
They will be visible unless they are Attached Orders and the parent order has not yet filled.
