Date/Time: Sun, 19 May 2024 05:07:13 +0000
Copying symbol list to another computer
View Count: 621
[2016-07-14 17:30:19] |
User982736 - Posts: 46 |
I created a symbol list on one computer and entered data into the comments column. When I copied the symbol list to another computer the comments did not show up. How do get the comments copied as well? |
[2016-07-14 17:59:36] |
It sounds like you are referring to the Quote Board. These are part of Chartbooks. So you need to copy the entire Chartbook. Here are instructions: https://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html#CopyChartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-14 18:05:49] |
Yes, I meant Quote Board. Thanks.
[2016-07-14 18:33:48] |
I copied the cht file over and the comments still do not show up.
