Date/Time: Sun, 19 May 2024 06:11:40 +0000
Chart size has grown dramatically
View Count: 614
[2016-07-14 13:17:22] |
User52989 - Posts: 42 |
Hi, 7yr Sierra user, have accumulated quite a few charts over the years. Currently my primary chart is just a 2 range bar intraday ES, with a couple moving averages and basic subgraphs, such as stochastics and MACD. The chart has always ranged from 275kb-400kb; something has happened in the last couple weeks of upgrades where it has grown in size to 2MB. I have added nothing to it. Again, just a single chart, with only 10 days of data, not 30 or 60. Any clue on why it has grown so massively with no changes? Thanks.
[2016-07-14 13:43:22] |
BTW running v1445
[2016-07-14 16:23:20] |
We are not sure how you are measuring this. We do not know how you can reliably measure this. Assuming you have a reliable means to measure this, we are not sure about the increase in size. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-14 16:55:22] |
When you click FILE -> SAVE AS it shows you all the saved charts and their sizes. The identical chart was saved 3wks ago under a different name, and is 279kb; since Sierra's newest version, it's now 3MB, a massive increase, even though nothing has changed with the chart, no new indicators or anything.
[2016-07-14 17:06:20] |
OK we see. You could have a lot Chart Drawings in the chart taking that space. It must be something. Create a Chartbook with a new chart and save it. You will see the file size is 20 K. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-14 17:12:58
