Date/Time: Sun, 19 May 2024 13:52:52 +0000
Chart Drawing Not Visible
View Count: 1329
[2016-07-13 19:22:02] |
User112361 - Posts: 3 |
Hello - I've draw an extended rectangle on my chart but it isn't visible. The properties say it should be. No the colors(s) aren't white. Other drawings on other charts of other symbols work fine, just this chart is fubar. What is going on? Thanks Bill
2016-07-13_1315_Sierra_Chart.png / V - Attached On 2016-07-13 19:18:55 UTC - Size: 39.66 KB - 301 views |
[2016-07-13 20:34:20] |
When you draw another one do you see it? Do you see it appear as you are drawing it?
[2016-07-13 20:42:30] |
I see the drawing, as I draw it, but when I left-click to finalize, it disappears. It can be ANY drawing type. BUT, it shows up in the 'Manage Drawings Window'.
2016-07-13_1439_Sierra_Chart.png / V - Attached On 2016-07-13 20:41:10 UTC - Size: 60.77 KB - 300 views |
[2016-07-13 20:45:26] |
Uncheck Chart >> Hide Chart Drawings.
[2016-07-13 20:46:55] |
That fixed it. Thanks
[2019-05-20 16:52:37] |
User153389 - Posts: 1 |
Hi, I'm having the same issue as Bill had. But my "hide chart Drawings" is not checked. I have even checked and unchecked it. I can easily draw, hide and unhide drawings on minute charts but not on my tick charts or second charts. Thanks for your help. |
[2019-05-22 04:05:42] |
What you are describing does not make sense. Hiding and showing of drawings is not affected by the type of chart bars.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-22 04:06:18
