Date/Time: Sun, 19 May 2024 00:53:15 +0000
DTN Connection Issue
View Count: 662
[2016-07-13 17:15:57] |
Sierra Chart - Max - Posts: 5618 |
the software is trying to load but this message appears: IQFeed | Connecting. | 2016-07-13 12:19:08 IQFeed | Connecting to Admin port 9300 | 2016-07-13 12:19:08 Socket (70) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-07-13 12:19:12 Socket (70) | Shutdown and closed. | 2016-07-13 12:19:12 IQFeed | Disconnected from Admin port. | 2016-07-13 12:19:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-07-13 12:19:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-07-13 12:19:12 Starting DTN IQ Feed interface software. | 2016-07-13 12:19:12 IQFeed | Disconnected. | 2016-07-13 12:19:12 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-07-13 12:19:12 Sierra Chart Support |
[2016-07-13 17:34:30] |
Follow through the IQ Feed setup instructions here: DTN IQ Feed Data Service: Setup Instructions If you need further help contact IQ Feed support for help with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-13 17:36:48
