Date/Time: Sun, 19 May 2024 04:56:09 +0000
data feed in new instance
View Count: 1090
[2016-07-13 00:18:46] |
User705641 - Posts: 38 |
IU have been using new instance for some time but since uoloading a new version when the instances start up the date/data trade service settings do not have SCForexData(FXCM) data settings and when I go to the service box I cannot change it to the relevant data feed. Can You give me some guidance please
[2016-07-13 04:00:55] |
When using File >> New Instance you cannot change the Service in the sub instance. How this works is all documented here: https://www.sierrachart.com/index.php?page=doc/doc_DTCServer.php#UsingDTCServerForDataAndTradingInAnotherSCInstance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-13 12:30:21] |
thankyou I am aware of that - on restarting is it normal that logging in and out of data feed is necessary before the chart begins to update
[2016-07-13 16:15:58] |
No this is not normal. If you notice a problem with the charts not updating, refer to help topic 3: Https://www.sierrachart.com/index.php?l=helpdetails3.html If you still need help we need to know the symbol of one of the charts and we need to see the Message Log. Provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
