Date/Time: Sun, 19 May 2024 05:07:16 +0000
heat map
View Count: 3869
[2016-07-12 21:55:53] |
User705641 - Posts: 38 |
Hi where do I find the new heat map feature please. Is it only available for futures feeds?
[2016-07-13 03:49:36] |
What you are looking for is documented here: https://www.sierrachart.com/index.php?page=doc/MarketDepthHistoricalGraph.php You cannot use it with the cash Forex markets unless you are using LMAX: LMAX Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
