Date/Time: Sun, 19 May 2024 14:55:17 +0000
Program Alert??
View Count: 731
[2016-07-09 15:06:56] |
User_ML - Posts: 17 |
I am trying to use the Color Background Based on Alert Condition. I want to color the chart background either RED or Green according to if a moving average is above or below a different moving average. I have tried many combinations but still getting errors??? This is what I am trying to do =(ID2.SG1>ID4.SG1) |
[2016-07-09 22:04:11] |
The formula looks correct. What is the error message that you see in Window >> Alerts Manager >> Alerts Log? Select the Alert line, select Edit >> Copy Selection and paste it here. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-09 22:35:35] |
Alert Formula Error - Chart: ESU6 3 Min #1 | Study: Color Background Based On Alert Condition | Error: #SYNTAX! | Formula: =(ID2 .SG1< ID4.SG1) | No alert sound/email set
[2016-07-09 22:37:48] |
[2016-07-10 00:45:32] |
Remove the space after ID2: =(ID2.SG1< ID4.SG1) We will solve this in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-10 03:16:04] |
Thank You
