Date/Time: Sun, 19 May 2024 12:53:44 +0000
Updated software and Sierra will not boot
View Count: 633
[2016-07-07 13:51:21] |
User925659 - Posts: 39 |
Hello, I went to update to the newest version of Sierra to run the market depth history. The installer client stopped responding and crashed. I then attempted to load the update multiple times and now Sierra will not boot. I have had this issue since yesterday. I have tried multiple restarts of my machine, I have tried running the install client to update the software since and I can not get Sierra to boot. At this point I am at a lost. I do not use Sierra as my primary chart software but I do use Sierra for my DOM. Without Sierra loading I can not put on trades. Any guidance will be greatly appreciated/ |
[2016-07-07 16:17:11] |
Sierra Chart - Max - Posts: 5618 |
Let us know if you are still having the problem.
Sierra Chart Support Date Time Of Last Edit: 2016-07-07 16:17:40
[2016-07-07 17:08:12] |
We see you are currently logged into Sierra Chart. So are you still having this problem?
