Date/Time: Thu, 16 May 2024 05:35:09 +0000
Sierra's feed currently suitable for number bars. ?
View Count: 655
[2016-07-07 03:11:02] |
Peter - Posts: 9 |
Hello, i have a question about the sierra feed. Iam new to Sierra, have checked all settings and also used the "delete and download data" link several times but if i check the data with kinetick there are differences to large. My main interest is Eurostoxx, did not check any other instrument. Any other people use the Sierra feed with eurostoxx ? or does everyone use IQfeed ? Sidenote: ofcourse Kinetick can be wrong.... will try to verify this but have to find someone who uses IQfeed.... (or other feed) Date Time Of Last Edit: 2016-07-07 03:18:30
sierra-NT8.png / V - Attached On 2016-07-07 03:13:43 UTC - Size: 428.9 KB - 256 views |
[2016-07-07 04:20:38] |
Make sure Sierra Chart is set for a tick by tick data configuration: https://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php In the case of EUREX there is no indication received from the exchange indicating whether a trade is at the bid or ask. So there will be differences between data feeds with how this is determined. There is a method for the determination and it is documented here: https://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php#Definitions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-07 04:21:05
